I'm sure I'm not the first to try getting a KFLOP to drive a Gecko G540, but for the life of me if I can figure out how to get it to work. The KFLOP appears to be working correctly, as it connects to KMotion properly and responds to the Version command and flashes properly (and is run off a dedicated power supply). I've made up a cable to connect pins 15 and 16 on the KFLOP JP7 to pins 2 and 3 on the DB25 on the Gecko, set Channel 0 in Config&Flash to No Input, Step Dir, Input 0 (open loop, so I think this is unneeded), Output 8. The Fault light on the Gecko is not on, so near as I can figure this should work. Sadly when I go to the Step Response screen and set it up per the Step&Dir example nothing happens when I hit Move. Well, that's not quite true.... On the Axis screen the Dest changes, but the Position does not and the stepper just sits there. The Gecko worked just fine on the printer port of the computer I'm replacing, but seeing as
that machine is currently nonfunctional and the only one I have with a printer port I can't verify the Gecko.
Any thoughts on how to get this to work?
-aric.
